Tachometer for Echo? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2005, 07:17 PM   #1 (permalink)
42 mpg and loving it.
View Barewires's Photo Gallery
Hi, I'm new here. I have a stock 2002 Echo with manual transmission. I love this car and feel quite smug every time I pass the gas pump. However, the car is begging for a tachometer. Does anyone make an aftermarket tach that is practical and presentable with the dash layout? Thanks.
Barewires is offline   Reply With Quote
Old 04-07-2005, 09:46 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
TuRD has some CF POS that goes where a normal cluster would. Looks like ass IMO, but some may find it appealing. Any tach capable of DIS use will do if you can find a mount.
Old 11-13-2007, 07:50 PM   #3 (permalink)
View echo987's Photo Gallery
Talking Tach in Echo.
I just put one in today. Almost any tach will work. I got a sunpro from autozone, white face. The small one is $30 the larger one is about $45. I did some research and found out how to install without cutting into the wiring harness. you can mount it almost anywhere. I put mine on the steering column behind the steering wheel where you normaly have guages. it looks good in the car.
echo987 is offline   Reply With Quote
Old 11-14-2007, 10:13 PM   #4 (permalink)
View monsterzero's Photo Gallery
Hey Im new here I have a 2001 Toyota echo coupe. I recently purchased a Sunpro tach and I am having one hell of a time installing it. The shop down the road wants $150. Can some of you guys that installed tachs on your echos help me out.
monsterzero is offline   Reply With Quote
Old 11-15-2007, 12:42 AM   #5 (permalink)
Echo Tach install
Hey there. install is a snap. Sunpro, four wires. Black ground to good metal surface. I found a bolt on a metal bar that runs along the bottom of the dash, easy to get to, 10mm wrench. Red wire goes to fuse box in dash. Connect wire to ACC fuse, left side of fuse, this is important so that fuse will protect your car. Green wire goes to your OBDII scan plug under dash, this is a white computer like plug set up for 16 pin connection. Plug green wire into the first pin on the bottom row. White wire for lights. I found a wire behind my radio that was designated for lights and not being used. I have an aftermarket radio and it didnt require a connection for lights. I simply connected the white wire there and it works. if you don't want to go searching for a wire to connect to for lights, you can connect to the same ACC fuse as earlier, and the light on your tach will come on when you turn the car on. Good luck
Old 11-15-2007, 03:47 PM   #6 (permalink)
View rayrayII's Photo Gallery
I have a 2001 toyota echo sedan and I installed the sunpro tach with 7 different colors that was 45 and it works great. All the sunpro gauges from my experience work good with the echo. I also have their volt and air/fuel on my a pillar and it is awesome.
rayrayII is offline   Reply With Quote
Old 11-15-2007, 08:18 PM   #7 (permalink)
Hey man thanks a lot. I just have two questions, where is the OBDII and how hard is it to get to? And how do you wire a wire to a fuse? Thanks again
Old 11-15-2007, 09:24 PM   #8 (permalink)
tach install
The ObdII is on the drivers side at the bottom the dash, below your fuse box, mine is a white and mounted on the front edge of the bottom of dash, easy to get to, and easy to see if you look under your dash. it is set up to recieve a 16 pin computer connection this plug reads your cars computer. The plug has two rows of 8 pins. The first pin on the bottom row is for the tach. I used a horseshoe like connector and pinched the horseshoe together and slipped one prong of the horseshoe into that first pin on the bottom row. This isn't a professional install, but it works for me. I didn't want to cut into any wires so however you get it to plug in and stay should be fine. To connect to the fuse, run your wires behind the dash and pull your ACC fuse. Take that red wire and strip about a half inch of bare wire, twist end a little so you dont have any strays sticking out. Stick wire into left hole where ACC fuse goes, then stick ACC fuse in to hold wire in place. Electricity travels from the right side of the fuse to the left side, the left side is important so that the fuse does it's job and protects your car. I hope this helps. I love having a Tach. it makes all the difference.
Old 11-15-2007, 10:37 PM   #9 (permalink)
Alright man thanks, a lot. As long as it inst raining tomorrow I'm gonna give it a shot and hopefully it will work. I was trying to install this the completely wrong way.
Old 11-16-2007, 11:50 AM   #10 (permalink)
View jlift's Photo Gallery
Why not just get a scangauge II which has a tach function built into it. Plus, you get alot of other gauges for the car. Plugs into OBD port. scangauge.com I have the older version, but the new one is alot slimmer and looks cooler.
jlift is offline   Reply With Quote
Old 11-16-2007, 12:14 PM   #11 (permalink)
Because I already bought the tach and cant return it.
Old 11-16-2007, 01:42 PM   #12 (permalink)
Hey one last question what should my echo be idling at its around 1000.
Old 11-16-2007, 03:49 PM   #13 (permalink)
I fixed the idle but I have a problem with the stock gauge lights now. They don't turn on. Someone help please quick.
Old 11-16-2007, 06:47 PM   #14 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664359
View ECHOKnight2000's Photo Gallery
I have a Scanguage II which is nice but the read out is small. Kinda wish I had a bigger tach read out but otherwise pretty nice device.
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 11-16-2007, 07:10 PM   #15 (permalink)
Fuse?
check your fuses, if you didnt cut any wires, it is in your fuses.
