lighter plug 2000 echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2005, 12:47 PM   #1 (permalink)
View joycemarie's Photo Gallery
USA lighter plug 2000 echo
Any advice out there re: why no juice to my 2000 Echo's cigarette lighter? Fuse checks OK but the wire at the back of the lighter is dead. It worked until I used my 12 volt coffee pot a few times. This pot occasionally blew fuses in other cars but replacing the fuse always fixed it. Where do I look next?
joycemarie
spambedam@yahoo.com
joycemarie is offline   Reply With Quote
Old 07-04-2005, 04:36 PM   #2 (permalink)
幻影
Phatfantom68's Avatar
View Phatfantom68's Photo Gallery
Check the wiring. If your coffee pot has blown fuses in other cars, it may be drawing too much current for the wires to handle.
1991 Lexus LS400 (UCF10)
1991 Toyota Camry DX (SV21)
1984 Toyota Celica GT (RA64)
1994 Ford F250 XLT
Phatfantom68 is offline   Reply With Quote
Old 07-08-2005, 04:52 PM   #3 (permalink)
The fuse should go before the wires and it did not blow. What I can see of the wires looks OK.
Joyce
Old 07-12-2005, 03:44 PM   #4 (permalink)
roc
Jedi Knight.
View roc's Photo Gallery
With a voltmeter, check the contact points inside. You may find that you are getting little or no contact. If that doesn't work.....you must dig deeper. BTW if you don't have a voltmeter, you can usually pick one up at any automotive place for $10+ depending on the quality that you want. For most wiring people you can get away with a cheapy(unless you are an electrician).
Size matters not! Judge ME by my size do you? Hmmm?
roc is offline   Reply With Quote
