CHECK ENGINE light, codes: P0440,P0441,P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2005, 09:09 PM   #1 (permalink)
View Andrey12's Photo Gallery
Hey everyone!
I bought my Echo only 3 weeks ago. I changed oil and put syntetic oil, I change also spark plugs on original denso spark plugs with right gap. Now here's my problem. I filed my tank full and after driving at night CHECK ENGINE light come off. I checked spark plugs, I cleaned this two small heated wires on MAF and disconected battery so light go away.
However after one week the same story, I filed my tank full, drove about 100 miles and again at night my CHECK ENGINE come up.
It may be a coinsedence it may be not, but both times it happened at night and approximetly after 100 miles after filing the full tank.
My codes are : P0440,P0441,P0446.
Any sugestions guys?
Andrey12 is offline   Reply With Quote
Old 08-16-2005, 06:28 PM   #2 (permalink)
View ffpmlex's Photo Gallery
The codes your vehicle gave all point to the Evaporative Emission Control System. Is there an abnormally strong fuel odor in the engine compartment? If so, look for leaking fuel lines, a damaged/cracked charcoal canister. Check for a stuck check valve.
ffpmlex is offline   Reply With Quote
Old 08-16-2005, 08:19 PM   #3 (permalink)
Nope, no fuel odor.
Where is located charcoal canister and stuck check valve?
Old 08-17-2005, 03:54 AM   #4 (permalink)
Wink
Looks like I found something that might cause the problem. The vacuum hose from air cleaner to canister was disconected
I bought this car 3 weeks ago and all this time I was driving with this disconected hose. I hope it was the problem. I will find out pretty soon.
Thanks buddy a lot for advise to check hoses, it was a really good advise.
Old 08-24-2005, 02:29 PM   #5 (permalink)
Glad you fixed the problem so easily...you should clear the check engine light malfunction code by clearing it with an OBD scan tool if possible. If you don't have one, you should at the very least disconnect the battery so that the check engine light shuts off...that way you can see if it goes off again.
Old 01-09-2007, 03:45 PM   #6 (permalink)
View b lee's Photo Gallery
hey there i got this 1999 toyota carmy v6 3.0 liter engine come on i have the car check and theres an engine code #p0446 it have to do with evap emission. can any body give me an subjestion.cause i hae already replace the purge valve and gas cap. but there this other press release valve i haven't replace could that be it.
b lee is offline   Reply With Quote
Old 01-15-2007, 04:33 PM   #7 (permalink)
Browntown
View ajrinthepeg's Photo Gallery
check the vaccum switching valves (vsv) they may may faulty
ajrinthepeg is offline   Reply With Quote
Old 01-22-2007, 07:56 AM   #8 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
Make sure th gas cap is on tight. This is the most common reason for a CEL after re-fueling. If you tighten it, reset the light by pulling the negative battery cable for a few minutes. The light will go out on its own after a few trips if you don't want to pull the battery cable. If the CEL returns, there is a separate issue.
2003 XRS - Indigo Ink Pearl
K&N Typhoon SR
Magnaflow Cat back Exhaust
Energy Suspension Motor Mounts
Speed Source Cable / Shifter Base Bushings
wantin150 is offline   Reply With Quote
