help replacing lights behind cluster!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2005, 06:58 PM   #1 (permalink)
Damage82's Avatar
View Damage82's Photo Gallery
Canada help replacing lights behind cluster!!
I haven't looked at how to remove it, but I'm at work and my wife says the light behind the gas gauge and about a 1/4 of the speedometer is not lit in her 2003 echo sedan. How do i take this out and where is the best place to get the bulbs? Thanks in advance
2006 Chevy Colorado 4X4 ext cab 2.8L (mine)
2003 Toyota Echo Sedan grey 462000kms(wife's)
1995 Toyota Tercel 2 Dr Black (burnt valve, gone)1993 Toyota Tercel 4 DR (gone)
www.canadiankrazymods.com
Damage82 is offline   Reply With Quote
Old 08-24-2005, 11:47 AM   #2 (permalink)
Toyota Fan
View Todd Soden's Photo Gallery
could be a fuse...may want to check that first.
2000 Camry CE
2000 Echo
Todd Soden is offline   Reply With Quote
Old 08-24-2005, 12:39 PM   #3 (permalink)
幻影
Phatfantom68's Avatar
View Phatfantom68's Photo Gallery
If the 04 cluster is similar to the 00, than here's how u get to the bulbs:
-Grab the plastic trim thing and pull it straight out.
-Unscrew the cluster, and remove the wire harnesses
-from here, just twist the bulbs out and replace them
- put everything back in reverse order
As for where you buy the bulbs, I'm not sure, but you can check any local car parts store.
1991 Lexus LS400 (UCF10)
1991 Toyota Camry DX (SV21)
1984 Toyota Celica GT (RA64)
1994 Ford F250 XLT
Phatfantom68 is offline   Reply With Quote
Old 08-24-2005, 01:15 PM   #4 (permalink)
Damage82's Avatar
Canada
wouldn't that make all the lights go out?
Old 08-24-2005, 01:15 PM   #5 (permalink)
Damage82's Avatar
Canada
thanks, i'll give it a try this weekend.
