Recommended 17" tire size? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2005, 09:43 AM   #1 (permalink)
Yaris Xrs
View peter Gabrovsky's Photo Gallery
I just purchased a set of OZ Superturismo-GT wheels for my 2006 Yaris RS (hope fully in arriving November - wheels will be for summe use only)
17"x7" 44mm offset
Recommended is 205/45 -17 (as seems to be an option in Japan)
DOes anyone run 205/40 -17 or 215/40 -17?
Any one with pics of these tire sizes on an Echo/vitz?
Thanks!
peter Gabrovsky is offline   Reply With Quote
Old 09-22-2005, 11:34 PM   #2 (permalink)
Yaris Xrs
Looks like 205/45 17 is the right option.
TRD 17" wheel for the Vitz......very nice!
http://trdparts.jp/english/parts_wheel-tf1.html
Old 10-05-2005, 11:09 AM   #3 (permalink)
View Recon's Photo Gallery
I have the 205/40 17 on these ADR rims. they only have a 40mm offset and rub when I hit a bump at highway speeds. I thinks the wing pushes the rear down to much at those speeds. The bumps on back roads will kill you, try to not hit any sharp edges like at a construction site. Where you have to go up cut pavement, if you hit it at speed the low profile tire will knock your teeth out.
Recon is offline   Reply With Quote
Old 10-05-2005, 04:47 PM   #4 (permalink)
echo_hrs's Avatar
View echo_hrs's Photo Gallery
2006 Yaris is a completely different car from the Echo Sedan/Hatch so the fitment/offset is completely different as well...
echo_hrs is offline   Reply With Quote
Old 10-05-2005, 07:40 PM   #5 (permalink)
Yaris Xrs
Yes ...I noticed on the Japan OZ Wheels website shows an offset of 44mm for 17" x 7" for the "new Vitz".........
If the factory is mounting 17 x 7 on the new platform with 205/45 - 17 it must work (with the correct offset).....If I remember correctly, the 17x7 TRD wheels are listed with a 50mm offset...
