Disconnect the battery and wait 2 minutes before work, and you won't pop your airbags.
Mark where the old wheel is pointed so you can put the new wheel on oriented properly.
Not sure if you will have place there to wire your remote back to the car. If the spiral cable doesn't have enough conductors or you can't plug the remote in you're SOL.
If your leather wheel does not come with airbags (most likely so), and the airbag shapes are different, you are also SOL.
Do you need to transfer the cruise control stalk over, if one's there?
