Well, 95% of the time it;s 1 of 2 things.
1: The switch(s) themselves are bad.
2: The door wiring broke, which is VERY common. The wires in the rubber tubing between the 2 front doors and body is where to look. Undo the plugs behind the kick panel, take the door panel off, and pull the harness out from the body, into the door, then out from the door where the door panel would be. That gives yourself a lot of room to inspect it. Pull back the rubber and examine all the wires. Any you see broken, solder and heat shrink back together.
Like I said, itls very common, so thats likely the issue.
5 Lug Corolla WHAT?
