Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
View Single Post
Old 01-01-2009, 01:44 PM   #12 (permalink)
dz63
Gameroom cash: $106900
View dz63's Photo Gallery
Originally Posted by Stillrunning View Post
I've always done it on my used vehicles and had no problem. I think it's bunk if you think that somehow dirt is holding your transmission together. Would you change the engine oil on a used car?
What I have read, but admittedly cannot substantiate, is that it is not good to flush the transmission. The concern raised is that flushing may dislodge some debris which could get caught in a valve body or some other part of the transmission. After doing some further research, I discovered that there are a lot of opinions out there on this topic. I found this link below. It has some good information and explains several types of transmission flushing machines.
Transmission Flush Scare
I also found a DIY procedure to flush the transmission:
DIY flush transmission fluid
I plan to give it a try and will post back with a modified procedure.
EDIT: Stillrunning is correct! If you only drain and fill the transmission, the existing dirty fluid in the cooler and torque converter quickly contaminates the new fluid that you just added. After running the vehicle for only a few days, I noticed that the new fluid was looking brownish again. Note that it only take about 15-20 minutes and an extra 6-8 liters of clean fluid to get all of the old fluid out. In hindsight, I would recommend the removing the transmission cooler lines in order to get all of the dirty fluid out. It is a much better method in my opinion than just draining the transmission. I have updated the above procedure to reflect this.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
Last edited by dz63; 01-19-2009 at 11:29 AM. Reason: Added EDIT notes & removed the term "flush"
dz63 is offline   Reply With Quote
