Ok injectors are good! And a pain to get to! The car is now intermittently running well. It set off cyl #1 again and it died on me while i was backing it out of the driveway which set off a P1300 Igniter circuit fault 1 or something like that! Which ive had before. So I started it back up and it was running aweful, and blowing lots of unburned gas out the pipe. I cleared the code and it started running ok again. Let it idle for a while and it didnt set off any codes. It only seems to have problems under load. It I put it in drive or reverse it seems to automaticaly start missing. What should I do next?
