I picked up the car today. The mechanic said that when he switched the aftermarket converter with the Toyota converter the problem didn't go away. However, he was receiving error codes and the check engine light did come on. They codes indicate a problem with the cam sensor. He was not getting codes with the after market parts. Who knows. He replaced the distributor and so far the car seems to run well. He did check the timing and said that was not a issue. He also verified that the wires and plugs were good.
With luck, I am hoping that this solves the problem.
