Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Mobil1 5w-30 Synthetic and my 2002 Corolla???
View Single Post
Old 01-23-2004, 06:37 AM   #6 (permalink)
gadawg
View gadawg's Photo Gallery
Originally posted by TofuRacer
Dude, First of all NEVER ever do this again.
A Toyota Corolla will give you the most outstanding quality in dependability and reliability, take care of your baby, consider this car as a sacred extension of your outer self
Anyways your oil was burnt, or used up inside your combustion chamber, you might not have realized it but your car might have been producing a black smoke coming out from it's exhaust while you were driving it. You should really not worry about any extensive problems that your car might have, although in the long run you might want to change your piston rings.
A simple advise on preventing your car from completely giving up:
1) Use a fewel cleaner or a fuel inline cleaner to add to your gas tank
2) When changing your oil, make sure to change the filter and replace the rubber bushing from the bolt in your oil pan.
3) Use a 10W-30 oil viscosity in your oil, (Best suggestion is to use Quaker State Semi Synthetic), four quarts of these babies and your set to go on the road again.
Let me set the record straight: my car is nowhere close to giving up...it is not dying nor is it mal-maintained. i am doing the same things i have always done in the past: oil changes every 3000-4000 with the dino oil, I just switched to synthetic.
1) I checked the oil about 2 weeks prior to my finding there was no oil registering on the dipstick. It was the last time I filled up with gas. No problems found.
2) I take extra special care of my vehicles. I keep meticulous service records and will continue to do so.
3) This is my first experience with synthetic motor oil. I never had any issues when using dino oil.
4) I never saw any smoke coming from the exhaust...I even rode behind the corolla a few times in the past few weeks (prior to the last oil change)...no smoke seen.
5) I am interested to know why you think I may need to change my piston rings in the future????
6) I do make sure I check the drain and filter when I get back from my test drive after each oil change.
7) 10w-30...this may actually hold some water as to my theory of the missing oil, since 5w-30 is so thin and since it's synthetic, it's extra thin. hmmm, i am going to try 10w-30 next time.
8) Fewel cleaner...i think you mean FUEL cleaner...hmmmmmmmmmm???????? why?
gadawg is offline   Reply With Quote
