Originally Posted by MrSo0h0o
check your sway bar bushings and end links to see if they are worn. If they are, replace them. Try and grease them with white lithium grease and see if it helps
Right on. I had this same rear creaking noise whenever I went over bumps. My mechanic lubricated the bushings and I've been OK ever since. According to him, it has to do with all the winter road salt and cold temperatures. I'm not sure what exactly causes it but greasing the bushings was the solution.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
