Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - knock sensor wire ciruit?
View Single Post
Old 02-12-2009, 10:57 AM   #3 (permalink)
gza808
View gza808's Photo Gallery
code 52 / problem fix
Originally Posted by kamesama980 View Post
Could you post up what the problem and solution were in case someone else has a similar problem?
ok...
PROBLEM: check engine light...code 52 - knock sensor.
WHAT I DID: I grab 2 knock sensor from a local junkyard off a 7mge, and replace it (we notice the one we remove was also new)....even though we replace it, my check engine light still came on.
SOLUTION: I had a talk with one of my buddy who is a Toyota Parts guy, he told me it could be a bad wire circuit. I basically went back to the junk yard and was able to get 2 knock sensor circuits and ran one of them to the ecu....i actually splice it in....PROBLEM was solved...no check enigne light.....
gza808 is offline   Reply With Quote
