Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Stuck high idle
Thread: Stuck high idle
View Single Post
Old 02-14-2009, 05:33 PM   #7 (permalink)
dj99
dj99's Avatar
View dj99's Photo Gallery
If the IAC is like others I've seen, then all you really have to do is shoot brake cleaner (or carb cleaner) through the air passage it while you cycle the electric solenoid with 12V. If it's sticking, this should do the trick. Do not shoot cleaner through the coolant passages with the hose tubes.
1993 Toyota T100 4WD 5-speed (Just over 50K!)
Formerly owned 1989 Toyota pickup 4WD 5-speed
Formerly owned 1985 Toyota Camry Turbo-Diesel
All of the above purchased new
dj99 is offline   Reply With Quote
