Pulled Trany pan. Clean, filter clean. Drained transfer case oil. Clean. Drained front differential oil. Clean. Refilled all. Filled with grease all zerts I could find on drive shafts and otherwise. Pulled front wheels and checked bearings. I shook, hit, turned, pounded, twisted pulled and pushed every thing or part I could put my hand on. I could not get it to make a noise until I drove it down the street. It clatters as much as ever. I can't see that it is in the engine or associated parts because the noise does not occur with engine rpms alone. Only in neutral while in motion above 15 mph. I checked around every shaft for anything that could be rubbing.
I am at a total loss on this. It is either something very simple or something inside the Transmission. I will try to get #2 son to video the noise tomorrow and I'll try to post it.
Thanks for the replies so far.
Alan
