help with code 11 22re 1987 4runner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 03-19-2010, 12:46 AM   #1 (permalink)
View superclos1's Photo Gallery
Gen1 help with code 11 22re 1987 4runner
im having a problem with this code im getting (11) i checked the timing and it way off, the line on the pulley is way over the left side i tryed adjusting it but it wont work... it only moves close but not to were its supposed to be.. any one know anything..
superclos1 is offline   Reply With Quote
Old 03-19-2010, 01:56 AM   #2 (permalink)
88 4runner
View Wilscojeff's Photo Gallery
Have you tried skipping a tooth on your distributor one way or the other. Not that hard to do but it is easy to skip more than one. Best way is to do it really slow. twist the rotor slowly back and for and you will feel when it come free. turn it slowly one way or the other depending on if you need to advance or retard the the timing. That should get you in the range you need.
Wilscojeff is offline   Reply With Quote
Old 03-19-2010, 09:32 AM   #3 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
superclos1,
There is the possibility that you have a worn timing chain and worn guide. This is a common problem with the 22r. This can cause the timing chain to jump timing and cause the problem you are having. If you don't know when the timing chain was replaced I would take a look at it to make sure there is not any wear going on in there. It can when loose cut through the timing cover and cause more problems. Oil leaks/fail etc.
jetwhine is offline   Reply With Quote
Old 03-19-2010, 10:09 AM   #4 (permalink)
i took the head cover off and the chain looks new with new guides, the chain seens to be tight..
Old 03-20-2010, 04:04 PM   #5 (permalink)
Superclos1,
So you had the head off. Lets go back to what Wilscojeff said. Put your engine at top dead center and check to see where the distributor is pointing. And if you don't have enough slot to adjust to point to #1 cylinder then your distributor is off by a tooth or so. You basically want to have the rotor point too #1 with enough slot on each side of the lock down bolt to adjust the timing.
The Following User Says Thank You to jetwhine For This Useful Post:
superclos1 (03-21-2010)
