superclos1,
You might try taking loose a fuel line in the engine compt. and jumper the pump and see if you have a steady fuel supply coming from the fuel pump. Catch it in a bucket so you don't have fuel running all over the floor. Make sure that it will continue to flow past the 3 second mark. Maybe even for say 5-10 seconds. It does sound like a fuel delivery problem, if you can keep it running with the starting fluid. You might have a bad fuel pressure regulator. 22r right?
