88 4runner diff ratio - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 04-12-2010, 09:57 PM   #1 (permalink)
Fergifruitchew's Avatar
View Fergifruitchew's Photo Gallery
My 1988 4runner front diff (the one i blew up) as it says is a 4:10 ratio Code of G292 (G= 8" Ring, 29= 4:10, 2= 2 Pinion)
My 4runner is a V6. Well i went and bought a used front diff to replace it, i looked for the same code on the same year 4runner and found a front diff code of G292, BUT it was out of a 22re 4runner and the diff also had an air lock mechanism on it. I installed it on my 4runner and it binds, so i now know its NOT the same... now why the same code but different ratios?
Fergifruitchew is offline   Reply With Quote
Old 04-13-2010, 07:16 AM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
What year/model was the replacement diff from? Maybe the previous owner regeared when he put the air locker in.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 04-13-2010, 10:15 AM   #3 (permalink)
i believe it was from an 87 4runner...im thinking he regeared aswell.... anyways i have another replacement diff now, its a G294 so it should work. its just a 4 pinion instead of 2 so its stronger i guess.
Old 04-13-2010, 03:25 PM   #4 (permalink)
out on bail
fourwd1's Avatar
A V6 rear diff should be 4 pinion from the factory.
The V6 front diff is the same as the 4 cyl, and both use 7.5" ring gears.
89 4Runner - stock
