1989 4Runner Vacuum Lines?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 04-13-2010, 10:11 AM   #1 (permalink)
View makedust's Photo Gallery
Question 1989 4Runner Vacuum Lines??
Looking for advice, when I holding in the brake and push the clutch it causes the engine to rev up and down, it doesn't stall out, runs fine when you are driving down the road and there is nothing else out of the ordinary. It has always displayed the code 52 and is not giving anything new for codes. Could it be a vacuum line issue and can anyone give me any guidance on where to start? It is a 22RE, 5 speed manual trans. Thanks
makedust is offline   Reply With Quote
Old 04-13-2010, 03:28 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Make sure your idle RPM's are in spec. Check the sticker under the hood if you don't know what it is.
If it's too high, adjust it into spec.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
