85 4runnr cooling - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 04-26-2010, 12:33 PM   #1 (permalink)
View mhowardconsult's Photo Gallery
85 4runnr cooling
My 4runnr developed a running water sound after cooling system service. I have air trapped in the heater core. I have tried elevating the front end and running the engine in order to bleed the system. I have tried this several times and I cannot get the air out of the system. I do not overheat nor have I located any leaks. Suggestions
mhowardconsult is offline   Reply With Quote
Old 04-26-2010, 07:21 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
You do have the heat set for Hot when you do it, right?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 04-26-2010, 08:08 PM   #3 (permalink)
Yup hot
Elevated front end and set to hot has made no difference at all.
Rather frustrating.
Thanks for the reply.
Old 04-26-2010, 11:58 PM   #4 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
mhowardconsult,
You can try disconnecting the in and out hoses to the heater core and with it on hot, try using a hose, force water trhrough the inlet line and wait until you have a good clean flow ( no air coming out of return line) and reconnect the lines. This might aid in purging the air.
jetwhine is offline   Reply With Quote
