Are you refering to the valve cover gaskets? If so, I know that not following the factory torque specs can cause leakage. I believe they only take 48 inch pounds for each bolt (11 on each side). I've read about alot of cases where people had leaks after changing the gaskets because of over tightening the bolts. Next time you feel like removing the valve covers, buy a new gasket and follow the Toyota Factory Service specs. Just google for "Toyota FSM". I'm sure that will fix most of your oil leak. I did this to my '95 and I'm glad I did.
1995 4x4 ext. cab Truck 3.0L 5-speed
1992 4Runner 4x4 3.0L Auto
