ct20 turbo getting red hot..HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 07-23-2010, 05:31 PM   #1 (permalink)
View scarface06's Photo Gallery
First off let me say, it's good to be here and glad to find this place.
I've had this turbo for atleast 5 years, the engine was rebuilt 3 years ago. I took all the emissions off several years back. Few months ago I rebuilt the turbo due to it pushing oil into the intake. After the turbo rebuild it has ran better than it ever has. Spools up fast and runs better.
I've found it getting light orange even after very light use. Last night after I got home it was bright orange as was the exhaust manifold. This was after a slow drive home for the final 2 miles just to help cool it down. It was hot enough I left it outside with the hood open because I was worried about it catching fire.
Any help would be great.
scarface06 is offline   Reply With Quote
Old 07-23-2010, 05:58 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I guess some things to check are the water lines to turbo. Any possible restrictions in the exhaust system(cat if you still have one) and ignition timing.
The Jedi Speeder at CarDomain
Old 07-23-2010, 07:23 PM   #3 (permalink)
timing is dead on. Exhaust has no restrictions and the high heat is coming only from the exhaust side of the turbo. The part that houses the bearings (where the water flows) isn't getting hot. It still has the $.99 paint on it.
Old 07-23-2010, 07:34 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Hhhmmm?
The only other possibility I can think of is exhaust valve clearance.
Old 07-23-2010, 09:36 PM   #5 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
You're probably running rich, could be a bad O2 sensor, etc.
Have you checked for any CEL codes?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-24-2010, 11:33 AM   #6 (permalink)
no codes at all. I will check the O2 sensor. The spark plugs look great. This would be a lot easier if the truck ran poorly.
I did find the plug for the air valve had come loose. What does the air valve do?
