I was going down the road just fine and the next thing I know I'm coasting... anyone been there?
turns over just fine
won't start on starting fluid
no spark coming from igniter/coil to distributer
tried 3 days later, won't start cold
new cap and rotor, still no start
rotor spins while cranking engine
checked distributer air gaps under rotor, OK
primary/secondary resistance test OK on coil
12 volts present on positive side of coil
high tension cord from coil to distributer OK resistance at 10 ohms
pickup coil OK all tested at 167ish ohms
unplugged computer and put 12 volts through harness towards igniter, saw spark off the coil doing this test
trigger pulse test inconclusive? (attach multimeter on little positive and negative wires of coil and crank) should go from 12 volts to zero to 12 to zero etc. very quickly mine jumped around like crazy around 8 - 7 volts.
because I unplugged the computer I can't pull code because without power they reset? discovered the "check engine soon" light bulb is burned out (when I go to start 4runner it does not come on like the rest of the warning lights) and yes I will replace it.
The computer terminal Igt to E1 (ground) test was inconclusive (not sure if I got a good connection and I had a trace amount of voltage before I turned the key to on, like 0.16ish volts)
Most of these tests are from the FSM, some are off the forum (yes I searched before asking)
my next steps are to buy an igniter on ebay (400 bucks at part store is ridiculous!) and check fuses with multimeter instead of just to look at them
Can anyone think of what I might be missing? Will it hurt my 4runner to just drive it one hour home by putting 12 volts via jumper cable onto positive terminal of coil? Don't know for sure if mine will run doing this, I've heard of someone else doing it.
Thanks a bunch, luckily I was able to get it to a friends house.
7" lift, headers, dual exhaust, 35's Detroit locker in rear, Trutrac LSD in front with 5.29 gears, bikini top, smitty built bumpers front n back, no carpet - roll on bedliner, alpine stereo system, K&N intake system, Warn Gold hubs, KC offroad lights
