A/C retrofit to R134 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 08-20-2010, 08:15 PM   #1 (permalink)
View Ron Hudgens's Photo Gallery
Cool A/C retrofit to R134
Anybody converted their A/C to R134? I have a 1986 4Runner with R12. Found a Toyota site which has a lot of info, but just wondering if all of it is necessary? The retro kits at Autozone are real generic and seem maybe too simple. Just wondering if any of you have done this successfully??? And what you HAD to do. Thanks
Ron Hudgens is offline   Reply With Quote
Old 08-21-2010, 12:44 AM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
I had mine converted several years ago. The system was in decent condition to begin with, and could hold a a vacuum. After the r134 ws added it lasted 3 yrs before the higher system pressure blew out the front seal of pump, which was to be expected because of the higher pressures.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 08-21-2010, 09:26 AM   #3 (permalink)
Thanks FOURWD1, The Toyota Tech bulletin(AC002-98) says to replace those o-rings along with the receiver/dryer and several other o-rings. You have to remove the compressor to do part of this. Did you do any of this on yours? Or did you do the Autozone way and just replace the freon fittings(High & Low), evacuate it and put in the R134? Anyway, thanks again for answering
