first off, is it worth it? my 3.0l v6 headgasket is gone but still runs great(not for long) my 4runner is a 5spd manual and i do have 2 spare 22re motors, would the 22re bolt onto this transmission?
To swap the motor is easy. Yes, the transmission will not bolt up. You will need to swap more than the engine. You will need the engine wire harness, ECU, etc.
If it were me, I would pull the 3.0 put it on an engine stand and do the headgasket, replace the seals, timing chain, etc since it is there.
It is very inexpensive to take a head in to get cleaned and machined.
OK, if the engine won't bolt to the trans, and the motor mounts, cooling, exhaust, ECU, and wiring need to be changed, how is it easy ??
