86 4Runner transmission question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 09-26-2010, 06:37 PM   #1 (permalink)
View ochs99's Photo Gallery
Hello, brand new here and hoping somebody can answer a simple question for me. I have a 86 4runner with a auto trans. I need to replace the transmission throttle cable or kickdown cable(not positive which it is called). I have it loose on the intake side and have taken out the bolt on the transmission side, but how do you actually get the cable out?
any help would be great!
ochs99 is offline   Reply With Quote
Old 09-26-2010, 07:36 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Throttle cable is the correct term, kickdown cable is the common term.
With the bolt out, pull up on the outter part at trans end and you should be able to see where the cable hooks into the trans side. It's sort of an S hook . You may have to disconnect it at the engine to get enough slack.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-26-2010, 11:46 PM   #3 (permalink)
I have it disconnected at the upper end and the bolt out where it connects to the tranmission, but it is attached inside. I am guessing I will have to drop the pan to be able to access and unhook the end of the cable.
Old 09-27-2010, 01:36 PM   #4 (permalink)
Dropped the trans pan and was able to unhook the cable, now just waiting for the new cable to put it all back together
Old 09-27-2010, 08:01 PM   #5 (permalink)
out on bail
fourwd1's Avatar
You're right, I was thinking of the KD cable on my 83. Glad you got it.
89 4Runner - stock
Old 09-28-2010, 03:53 PM   #6 (permalink)
anybody know the toyota part number for a kickdown cable for a 86 4runner with a auto transmission? parts store send me one for a 700-r4 trans
