Originally Posted by LMMW
The problem seems to be with the power windows. The windows are operable even when the vehicle is off. I can turn the vehicle off, remove the keys and still operate both the driver and passenger side windows.
Any ideas to why the windows would still work with the power off?
How long after you switch off the ignition and remove the key are the power windows still operable? Your 4Runner may have the "retained power" feature that allows you to operate the power windows for about a minute or until you open the door. Try it by switching off your ignition and removing the key, and then sit in your car for 5 or 10 minutes while not touching the windows until after that time has elapsed. Try it another time by switching off your ignition and removing your key, then immediately opening the driver's door, while not touching the windows until after the door is opened. If you can still operate the power windows after 5 or 10 minutes with the ignition off, or with the ignition off and door opened, you have a problem; otherwise it is just the retained power feature.
