Clutch issues 1987 4runner
Friends!
a few weeks back my clutch lost all of its fluid. luckily enough, i was able to get it into second gear to putz the 1.5 miles home off the interstate. I took it in and was told the hydraulic system needed to be replaced. Ended up replacing the master and slave cylinders, hoping this would fix all of the clutch issues i had. Sadly, this was not the case.
Before i lost all my fluid, I noticed that when I got off the interstate, first gear just didn't want to move the truck. it was like i was starting out in second gear when i was actually using first gear. When I would really hammer down on the throttle, the RPMs would get up to about 3,000 without really much acceleration. When i get above 3,000 RPMs, then you can finally feel something happen and acceleration picks up. It seems like this only happens when I get off the interstate or have been driving around town for a couple hours. This issue continued after replacing the slave and master cylinders.
My dad was thinking some of this fluid might be leaking onto the clutch, and once it burns off, the acceleration picks up.
Any Ideas?
1987 4runner. 4 cylinder. 5 spd. 4 wd. fuel injected. 253,000 miles.
