where is the air? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 01-02-2011, 12:11 AM   #1 (permalink)
View nv89runner's Photo Gallery
Gen1 where is the air?
Hey guys, I am new to this forum and was hoping I could get some ideas or help on this matter. I turn the fan on in my 4runner(89) and get no air from any of the vents. I took the dash apart and found that the hot/cold lever was broken along with the vent selection lever. After fixing both levers nothing had changed; still no air. The fan is spinning and you can hear it.
ANY ideas or solutions would be appreciated greatly, thnx!
nv89runner is offline   Reply With Quote
The Following User Says Thank You to nv89runner For This Useful Post:
YotaLuver (12-19-2011)
Old 01-02-2011, 01:15 AM   #2 (permalink)
Necos07's Avatar
View Necos07's Photo Gallery
U might have something stuck in ur vent, like a rats nest or something. Trust me it happens alot. lol
Necos07 is offline   Reply With Quote
The Following User Says Thank You to Necos07 For This Useful Post:
nv89runner (01-02-2011)
Old 01-02-2011, 11:56 AM   #3 (permalink)
Thanx Necos07, I will check the vents for blockage.
Old 01-03-2011, 03:15 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Is it just the upper (dash) vents, or all, or .. ?
Does the air come out anywhere?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 01-03-2011, 11:01 PM   #5 (permalink)
Problem solved! I took the whole dash apart (which I later found out wasn't necessary) along with the ducting. The problem was the A/C core/condenser (whatever it's called) as it was completely covered with dirt and grime and thus not allowing air to pass through the ducts. I now have plenty of air and heat
- and to answer your question fourwd1, air was not passing through any of the vents although you could feel a very slight draft from certain vents when the fan was on high
Old 01-04-2011, 08:22 PM   #6 (permalink)
out on bail
fourwd1's Avatar
Yeah, a clogged AC (or heating) core could block air thru all the vents.
Sometimes it's the simple stuff you don't expect.
89 4Runner - stock
