no heat but the temp gauge reads normal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 01-11-2011, 11:49 PM   #1 (permalink)
View jmbecker's Photo Gallery
i cant figure out why im not getting very warm air but everything under the hood seems fine. i rebuilt the engine about 8k miles ago the temp was fine during summer with the a/c on and off. the temp seems to be the same now thats its winter here in indiana but the air doesnt blow very warm at all. the only thing that is not new is the heater core but the heat blew fine when i tore it down to rebuild cause of timing chain guide break. anyone ever been through anything similar or have any ideas? thanks for any help.
jmbecker is offline   Reply With Quote
Old 01-12-2011, 12:02 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If it's not leaking, you may have an air bubble in the core.
Try bleeding the core and system again.
If not that, then you may have a restriction/blockage of some type in the core.
The Jedi Speeder at CarDomain
Old 01-12-2011, 06:55 AM   #3 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
jmbecker,
Have you checked to make sure your cable to the heater valve in the engine compt. is hooked up and working properly?? If that is working properly then you might want to do a heater core flush. It might have become clogged.
jetwhine is offline   Reply With Quote
Old 01-12-2011, 08:13 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
I'd check the cable from the heat control to the valve on the firewall first, as mentioned above.
Do you notice any gurgling sounds when you shut-off the engine?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
