AC Compressor/Air Pump Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 01-22-2011, 10:11 PM   #1 (permalink)
View 844Run's Photo Gallery
On my 1984 4Runner (22R Carb), either the AC Compressor or Air Pump sounds like it is losing a bearing. Is there any harm in disconnecting the belt that drives both? (The AC has not worked for over a decade, so I will not miss it.) Does one expect the smog system to still be "working" after 26 years?
844Run is offline   Reply With Quote
Old 01-22-2011, 10:18 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
If that's the only two things the belt drives, I'd say no problem if you don't have to worry about emissions testing.
I'd go look at my 84 to see, but it's like 10 degrees out there.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
