1988 4x4 truck intermitant miss - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 01-25-2011, 11:38 AM   #1 (permalink)
View TTRUCKER60's Photo Gallery
I HAVE A 1988 TOYOTA TRUCK THAT MISSES INTERMITANTLY. tHE VALVES WERE JUST ADJUSTED. ANYONE HAVE AN IDEA WHAT COULD CAUSE THIS. I AM A CLUELESS WOMAN...THAT GETS RIPPED OFF AT THE MECHANICS SHOP ALOT.
TTRUCKER60 is offline   Reply With Quote
Old 01-25-2011, 08:22 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
TTrucker60,
Ok I will throw a few questions at you.
When was the last time you had a tune up?
And what type of spark plugs were put in?
When was the last time the fuel filter was changed?
And when was the last time the Air filter was changed?
jetwhine is offline   Reply With Quote
Old 01-26-2011, 10:52 AM   #3 (permalink)
more info
Well.. the plugs have not been changed in a long time except for one..The fuel filter has not been changed since I've had it (at least 5 years) The air filter was changed recently. It did pass smog and it does not use alot of oil or blow smoke. I'm not much of an expert but I was wondering if it could be the plug wires?? It runs well otherwise and has power......it's kind of running like this.00000000x000000000xx00000000000000x0000000000 0xx the x being the miss...Thanks for helping.
Old 01-26-2011, 11:23 PM   #4 (permalink)
TTRUCKER60
The first thing I would do is change the spark plugs. Use only Denso or NGK. Any other brand brings havoc to Toyota's. If you have an owners manual, the plug numbers for the Denso and NGK are in it. Use only those numbers and don't let your parts guy tell you he has a cross reference for a different plug or brand. You need to use the exact number that the book calls for. If your parts store does not have the right ones go to Toyota and get them. You only want to change the plugs once.
This would be my first recomendation.
Then change the fuel filter. Wires don't usually go bad on a regular basis. But if the miss persists then wires would lnot be out of the picture. But do one thing at a time. So as to eleminate that item.
Old 01-27-2011, 10:48 AM   #5 (permalink)
Thanks
Thank-you so much for taking the time to reply. I am going to do those things and see if that helps. I will let you know if it works....
Old 01-27-2011, 11:46 PM   #6 (permalink)
TTRUCKER60,
Ok great, keep us posted with your progress.
