non responsive steering - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 02-21-2011, 08:29 PM   #1 (permalink)
View kvue's Photo Gallery
hello all,
I just got an 85 4runner, and the truck has a problem with the steering not responding very well. Driving at 30mph the steering system tends to be less responsive, and it gets worse as i drive faster. It becomes frightening to drive it on the freeway. Can anyone help me?
kvue is offline   Reply With Quote
Old 02-21-2011, 09:24 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Are the tires and suspension stock?
Power steering? If so have you checked the PS fluid?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 02-22-2011, 01:50 AM   #3 (permalink)
I was hoping you would reply...
Yes, i have check the powersteering fluid and gears. Fluid is good and up to level, and I have tried bleeding it as well. I have also check the powersteering gear box for leaks or external damage and found nothing. Also, the tires and suspension are stock. Though, i found several worn grease boots, can this be the cause?
Old 02-22-2011, 10:21 AM   #4 (permalink)
88 4runner
View Wilscojeff's Photo Gallery
Have you checked all the steering linkages. From the wheel down to the steering box?
Wilscojeff is offline   Reply With Quote
Old 02-22-2011, 02:40 PM   #5 (permalink)
Yes, all the linkages are in good shape. The only thing I see broken are several grease boots.
Old 03-05-2011, 10:29 PM   #6 (permalink)
88 4runner
Is the truck lifted? Whats size tires? Id check to see if the steering stabilizer shock needs replaced.
Old 03-06-2011, 02:11 AM   #7 (permalink)
The truck has stock supsension and stock tires. I haven't check the steering stabilizer yet; how would I know if the stabilizer needs replacement?
Old 03-06-2011, 09:38 AM   #8 (permalink)
88 4runner
you would have to take to shock off. If you compress it and it doesn't push back out then the shock is shot.
