passenger power window??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 03-21-2011, 11:34 PM   #1 (permalink)
View derekcase11's Photo Gallery
Question passenger power window???
hey everyone just got my first yota and its an 89 4runner with the 3.0 v6. It has all the power options, but when i got it it didnt have the power window switch and panel for the passenger side. I cant get it to go up and down with just the master button panel on the drivers side and was wondering if anyone knew if you had to have the other switch in for it to even work, if so can someone tell me where to find a switch or how to just install and different kind of switch ?
thanks for any help
derekcase11 is offline   Reply With Quote
Old 03-22-2011, 01:39 PM   #2 (permalink)
hey,
yeah it has a hole in the door for the switch its just missing and i tested the wires where it would plug inand they are getting power and so is the motor i guess ill just have to try and wire a switch my self for it ive seen some post on here how people moved them to a different spot so i might just do that but thanks for the reply i will look into the doors to see if they were changed at all
Old 03-22-2011, 09:01 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Looking at the schematic, it appears the pass side switch would need to be there to enable the drivers side switch to work
Any DPDT center-off rocker or toggle switch will work.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 03-23-2011, 01:51 PM   #4 (permalink)
wow ok thanks alot would you happen to have the wiring schematic for the passenger side that would show which wires would need to go where for a toggle?
thanks again you guys have been alot of help
Old 03-30-2011, 03:11 AM   #5 (permalink)
View kvue's Photo Gallery
Yeah, fourwd is correct. All three switches are parallel, you must have each switch connected to their window(s) for each individual window to work. The schematic diagram is confusing (I dont have it). It is best for you just go to the wrecking yard and pull one off from a truck or cellica.
kvue is offline   Reply With Quote
