t-case locked in 4H - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 04-18-2011, 10:26 AM   #1 (permalink)
View BlackSheep99's Photo Gallery
t-case locked in 4H
We are running a dual case setup with a 470 gear in the back case. The shifter in the back case gets stuck in 4H. The shifter looks like it would be in 4 high but in fact it acts like 2 high. Every time this happens we have to pull the shifter, move the selecting forks forward and reinstall it, then it works again for a little bit. It sounds crazy, but we did try turning the shifter around so that it faces away from me. This resolved the problem for only a short window. Any help would be greatly appreciated. We have been fighting this problem for weeks. Oh also, we have had the case opened everything looks great. The shift forks have been measured and do not need to be trimmed. Also reversing does not get it unstuck.
BlackSheep99 is offline   Reply With Quote
Old 04-18-2011, 09:00 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
That's a tough one. If the shift rods in the t-case can be move OK by hand, it seems like the problem would be with the shifter.
Sometimes a t-case can be hard to shift out of 4WD due to the drive train binding up, typically when you are on a hard paved surface. Have you tried unlocking the hubs first and making sure you are on a surface that can allow the wheels to slip a bit (dirt, gravel, etc) ?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
