OK, your 89 had an R150F-A and the 92 is an R150F-B. That explains the vent differences.
But that doesn't explain your problem. Since it was OK at first, I'm thinking some thing has gone wrong that has caused internal pressure to build up, causing the gear oil to be forced out.
Next question is if it's coming from the trans or the t-case. Have you checked the level in each ??
 SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
