Originally Posted by fourwd1
What makes you/them think the carb is not "Cali" standard??
It has more places for vacuum connections than what the California Vacuum diagram calls for.
Also, the box is California, as is the entire wiring harness. The PO wired up the entire connector wrong though, so now I am looking for that connector that plugs into the emission control box, if you know where I can get the plug and metal pins... I know it was re-wired because all of the connectors are soldered, rather than crimped.
Honestly, I am not sure how the truck runs as good as it does with the way this thing is wired. I am almost thinking about just running it down to the smog shop and seeing if it will pass.
