88 Pickup wont start when damp - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 05-03-2011, 12:43 PM   #1 (permalink)
View jodr's Photo Gallery
88 Pickup 4x4 4cyl.
This truck wont start first thing in the morning when its been raining or its damp. Its turns over but won't start. A few hours in the sun and it starts right up.
I just had the frame repaired and they took off the gas tank and fuel pump, then put the old pump back on.
Does anyone know how I should start troubleshooting this? Can the fuel pump sending unit assembly get wet and not work ?
jodr is offline   Reply With Quote
Old 05-05-2011, 08:34 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Is it carbed or EFI ?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 05-06-2011, 06:50 AM   #3 (permalink)
its an EFI
Old 05-06-2011, 09:43 PM   #4 (permalink)
out on bail
fourwd1's Avatar
That's what I figured. EFI has a whole lot of sensors that could be affected by wet conditions.
Unfortunately I can't figure which one could be causing your problem.
Any chance you checked the ECM for error codes?
89 4Runner - stock
Old 05-10-2011, 11:47 AM   #5 (permalink)
I did not check the ECM codes. Is that a standard check ? Would that be the first troubleshooting step?
Ive got the Haynes manual here next to me. It shows EFI main relay ECU and Circuit Opening relay under the hood. Any of these a possible cluprit.
Appreciate any guidance.
Old 06-01-2011, 01:04 PM   #6 (permalink)
It was a corroded distributor cap.
