87 4runner 15A engine fuse / alternator problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 09-03-2011, 04:39 PM   #1 (permalink)
View tim7802's Photo Gallery
When I turn on the ignition switch, the 15A engine fuse (fuse#8) blows in about 5 seconds. ( none of the gauges work, turn signals don't work---) This happens without the engine running. Without the engine running, the voltage across the battery terminals is about 12.6V. When I start the engine, the voltage does not increase - it stays at about 12.6V. When the lights and fan are turned on, the voltage drops. This seems to indicate that the alternator is not working. If the engine fuse is blown, will that prevent the alternator from working? Could there be a short in the alternator causing the fuse to blow?
tim7802 is offline   Reply With Quote
Old 09-05-2011, 11:32 PM   #2 (permalink)
Backup Light Switch Shorting Out
When I disconnected the backup switch, the engine fuse quit blowing and the alternator changed normally.
This is a good site for information on how the alternator works http://www.autoshop101.com/forms/h8.pdf
Old 09-06-2011, 07:47 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Did you figure out what in the b/u light circuit is causing the problem?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-06-2011, 09:16 PM   #4 (permalink)
Back up light circut
I don't know for sure yet. I cleaned the connector to the back-up light switch with electric parts cleaner. When I connected the back-up switch and turned on the ignition switch, the 15A engine fuse blew again. I didn't see anything in the service manual about how to test the backup switch, so next weekend I am going to buy a new one an try it.
