87 new clutch problems PLEASE HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 10-16-2011, 10:48 PM   #1 (permalink)
View 4runnerchase's Photo Gallery
Hey guys im new to this fourm ive been reading and looking around quite a bit and im having some trouble find the answer to my problem.
So i have an 87 4runner i just swapped a cherry 22re into and put on a new clutch and flywheel. i wnet to start it up and the clutch was slipping and very good. then i it hit me i forgot to clean all the parts with brake cleaner...
So i pulled out the tranny this time and took off the clutch sanded down the flywheel and cleaned all the parts with brake cleaner and installed using gloves.
then i also thought i would change out the master clutch cylinder and a new slave. bleed the whole system and went for a test drive i could kind of smell the clutch burnin a little and it would grab up to 3000 rpms then if i went anymore then that it would just slip. i have no idea what the problem can be im soo stump the tranny shifts very smooth and the 22re only has about 70k on it and very strong.
please help im at such a loss after so much work.
Thank you in advance
4runnerchase is offline   Reply With Quote
Old 10-16-2011, 11:23 PM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
4runnerchase,
The only thing I can think of is maybe that your fllywheel might be less than min tickness and even with a new clutch it might be too thin to grab right under high rpm's. But...... if you put a new flywheel in then it just might be a matter of missmatched parts that won't work on a Toyota.
jetwhine is offline   Reply With Quote
Old 10-17-2011, 12:06 AM   #3 (permalink)
Ya im pretty stumped anyone else have any input? please help
Old 10-17-2011, 02:36 PM   #4 (permalink)
bump i really need to get this thing drivable
Old 12-28-2011, 11:17 AM   #5 (permalink)
View nevada's Photo Gallery
do you have the correct freeplay on the clutch pedal?
where in the pedal travel does the clutch grab? at what point is the truck driving?
and this was a new flywheel correct?
nevada is offline   Reply With Quote
Old 01-01-2012, 06:56 PM   #6 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Are you sure you have the clutch disc facing in the correct way ?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
