Originally Posted by twalker
i had the alt tested at a shop and i used a voltmeter on the battery. i have also tried three different operational batteries.
Those bench tests aren't always accurate, and a voltmeter isn't the best way to test a battery, but 3 other batteries is something (assuming they were fully charged at the start)
i wonder if this has any significance:
the fuse for the hazard, reverse and marker lights blows as soon as i replace it....
Yes, it does. If any fuse blows right away there is a problem. Does it blow again when you replace it?
The rev lights, inst cluster warning lights, and turn signals work off of the 15A Engine fuse
The Hazard lights use the 15A Haz-Horn fuse (radio too).
The marker lights use the 15A Tail fuse.
What about the fusible links in the engine bay fuse panel, have any of those blown?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
