1986 4runner turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 1st Generation (1984–1989)
1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
Old 11-24-2011, 12:50 PM   #1 (permalink)
View nova19055's Photo Gallery
1986 4runner turbo
hi,,i have a 1986 22rtec,,turbo ,,it pouring white smoke out the exhaust,,i have had the turbo rebuilt also put a new head on it just yesterday,,still pouring white smoke and dripping coolant from exhaust,the bottom end of engine was rebuilt 5000 miles ago ,,,,im wonder if a cracked lower intake could cause this,,,ty for your time in advance
nova19055 is offline   Reply With Quote
Old 11-24-2011, 07:43 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
If the head and head gasket are new, and properly installed, that is a possibility.
It sounds like you had the problem before the head replacement, what did the gasket look like?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 11-25-2011, 07:50 AM   #3 (permalink)
back in june i had the engine rebuilt both the head and bottom end,,,about 2 week i was driving ,,it didnt over heat ,,,it just started pouring white smoke out the exhaust,,,,so i thought the turbo seals,,,had it rebuilt,,put it on same issue ,,,called my mechanic,, he said sounds like a blown head gasket or cracked head,,when i pulled the head off the head did look bllown between number 1 and2 ,,,also when i the upper part of the intake off coolant was the lower intake on 1 and 2 ,,,but just to be sure i also replace the head ,,,my last thought is the lower might be cracked at the thermosate housing
Old 11-25-2011, 01:10 PM   #4 (permalink)
i did pull the upper intake off today ,,,,no coolant in the lower intake,,,pulled the plugs all looked dry,if any has a email address i can show how much coolant was in the lower intake when i first started this ,,they were full of coolant ,,,,,,,after replacing the head ,,,no coolant in the intake ,,,,but still lots of white smoke from exhaust
Old 11-28-2011, 06:13 AM   #5 (permalink)
problem solved ,,,,was left over coolant in the exhaust ,,,just took time to burn off running great ,,no smoke
