Originally Posted by jcrm2666
I have a 4 cyl '07 camry with a 5 spd. I will drive 130 miles per day between 70 and 85 mph. I will usually get between 550 and 575 miles per tank. I usually fill up 17 gallons at a time, so i guess that equals out to be about 33 mpg. I think the key is to religiously rotate the tires and run them a bit higher in psi. I just replaced the factory tires at 65000. I run mine at around 37-38 psi.
At 37-38 PSI you don't have any issues with center wear on the tires?
