Truck not starting hot/dying - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 09-02-2010, 08:35 AM   #1 (permalink)
nukka
Vooduguru's Avatar
View Vooduguru's Photo Gallery
We've been fighting this problem for a while now. It's been a progressive problem. It started out where it'd just lose power once in a while like it just ran out of gas, but it'd get going again in a couple seconds. Then it got harder to start, and as it would crank, it'd billow out smoke. We thought it must be a gas issue, and really thought it was the injectors. We just changed out the injectors and it starts easier after it stops, but it still is a situation where we're cranking on it awhile. We also changed the fuel filter in the engine. The fuel pressure regulator was checked and it's fine. So what next?
Vooduguru is offline   Reply With Quote
Old 09-02-2010, 08:35 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
What color is the billowing smoke?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-04-2010, 12:02 AM   #3 (permalink)
nukka
Vooduguru's Avatar
It's black. So far we've changed the fuel filter, the fuel injectors, plugs, wires, cap, rotor and now the damn thing won't start. It "started" but idled at like 100ish RPM for like 20 seconds then died. It acts like it's not getting any gas. How hard is the fuel pump to change and clean the lines?
Old 09-06-2010, 01:34 AM   #4 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Vooduguru,
With that smoke being black I would say that you have some kind of spark issue. That sounds like unburned fuel. Should smell like it also. I would not suspect a pump problem, because you said that the pressure regulator is fine so I would think that the pump would be ok.
jetwhine is offline   Reply With Quote
Old 09-07-2010, 12:09 AM   #5 (permalink)
nukka
Vooduguru's Avatar
Originally Posted by jetwhine View Post
Vooduguru,
What else should I look at with the spark system? It's got new plugs, cap, rotor, wires, Should I check the coil?
Old 09-07-2010, 09:18 AM   #6 (permalink)
Vooduguru,
I don't think there are any specs on the igniter/coil. If you could pick one up for cheap at a local junkyard you might be able to get it started. Otherwise run some tests on the distributor to see if there is a breakdown on that. At this point it could also be the ECU. They are pretty hardy though, they don't go bad often.
Old 09-07-2010, 11:26 AM   #7 (permalink)
nukka
Vooduguru's Avatar
so check the coil first, then the ECU?
Old 09-07-2010, 01:44 PM   #8 (permalink)
nukka
Vooduguru's Avatar
Another idea I was kicking around, could there be a problem with ambient temperature sensors, where they may be sending in too much fuel?
Old 09-07-2010, 08:47 PM   #9 (permalink)
Vooduguru,
The only problem with the sensor is that is should start eihter cold and die after it gets hot or it is just difficult to start cold but at some point it should start. I bought a corolla one time and it was missing the cold start everything. But it would start just not right away. But once warm it would start without issues. I new this before hand and found all the parts needed to fix it.
I would look into the igniter/coil first. Like I said it is rare for the ECU to go bad, and as I said I would suspect something else first.
The fuel injectors will only allow so much fuel when triggered. If your regulator is working fine and the pressure is normal then I would think that there is no spark happening. I could be wrong and maybe I am but remember this is internet trouble shooting.
I am assuming that you have not pulled a spark plug out to see if it has a healthy spark? Because if it did that would blow my theory out the window.
Old 09-07-2010, 09:21 PM   #10 (permalink)
nukka
Vooduguru's Avatar
Vooduguru,
I replaced the plugs and my kids were far too efficient and threw them away before I could get pictures. These plugs were replaced about 5 months 3k miles ago. They were grey and had some carbon build up that was a medium gray, somewhat crusty on the electrode, but not too bad. I have new NGK's in there now. Could it be when the coil gets too hot that it sends a weak spark and that's what is causing the crusty buildup on the electrodes?
Old 09-07-2010, 10:32 PM   #11 (permalink)
Vooduguru,
It is very possible. Does it start cold?
Old 09-07-2010, 11:07 PM   #12 (permalink)
nukka
Vooduguru's Avatar
it starts almost immediately when it's cold. Drive it a while, full operating temp, stop, try to start it 10 minutes to 30 minutes later, and you'd swear its out of gas.
Old 09-08-2010, 09:24 AM   #13 (permalink)
Vooduguru,
Ok now we are getting somewhere.
It sounds like the cold start circuit is not shutting off after it is hot. There are two things in the system that will effect that.
1) Engine coolant temp sensor
2) Cold start timer
3) Bad/leaking cold start injector
I would start there and check that those two items are functioning properly. It sounds like it has been intermittant for awhile. Which could explain why it bogs down on you. When the sensor or the timer fail it will kick in extra gas and cause a bog down. This will cause hard starting when hot.
I would suspect the sensor first. And it might be a good idea just to replace it. They are not that expensive.
Old 09-08-2010, 09:34 AM   #14 (permalink)
nukka
Vooduguru's Avatar
Vooduguru,
2) Cold start timer
I disconnected the cold start injector and it ran and started fine for a number of hours. Then the same symptoms returned where would I find the engine coolant temp sensor, and the cold start timer?
Old 09-09-2010, 09:09 AM   #15 (permalink)
Vooduguru,
The temp sensor is located behind the intake manifold on top of motor next to the fire wall. There are I believe 4 sensors back there but the temp sensor has a green connector on it. Which directly influences the Throttle Position Sensor and the fuel system. Also the timer switch is located in the same area, it has a dark gray connector on it. I would not suspect the timer switch if you disconnected the injector.
Here is some info for the temp sensor:
1) 4-7 ohms @ (0c or 32f deg.)
2) 3K ohms @ (20c or 68F)
3) 0.9-1.3 ohms @ (40c or 104F)
4) 0.4-0.7 ohms @ (60c or 140F)
5) 0.2-0.4 ohms @ (80c or 176F)
