90 4Runner Gears - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 09-18-2010, 06:47 AM   #1 (permalink)
View Calgary Runner's Photo Gallery
90 4Runner Gears
Hey i have a 90 4cyl 4Runner that came with stock 4.10 gears. I have been wanting to upgrade them for a while. I recently found a great deal on some A040 gears from a 98 4Runner. I believe that that code is for the 4.56 gear correct me if i'm wrong. I would love to swap these into my truck if they will fit. Does anyone know if the gears are swappable between a 98 and a 90. Thanks
Calgary Runner is offline   Reply With Quote
Old 10-09-2010, 08:14 AM   #2 (permalink)
View 99blackSE's Photo Gallery
http://home.4x4wire.com/erik/diffs/
From Erik's site:
'86-95 4cyl Turbo and V6* trucks and 4runners, and ALL '96+ 4Runners use the Toyota 8" 4-pinion differential in the rear.
'95-03 Tacoma, '00-04 Tundra, ?? Sequoia's, and 96-02 4Runners have a high-pinion 7.5" IFS front diff offset to the drivers side. The high-pinion design is used so that the rack and pinion steering and anti-sway bar on these vehicles can run under the front driveshaft. The housing is a unique bolt-together design. The carrier inside is exactly the same as the '86-95 IFS diffs, so LSD's and lockers for it are also the same. However, since this is a high-pinion diff, the gears for it are different (reverse-cut) than the earlier diff.
So the rear would work but, someone correct me if I'm wrong, since the gears in the front are reverse cut you're hosed. I may be nabbbing another auto SR5 V6 this coming Wednesday so I'll check the door sticker, it might have 4.56 3rds as my '91 V6 did. If it does and you can wait till spring I'll hold them for you.
edit: If the reverse cut means the same as high pinion, as I understand with high pinion diffs you're running on the coast side of the ring gear. Not good for longevity as this tends to grenade them when you run on the coast side for extended periods (think rear diff). Front diff would not be as bad though, I think it's generally safe to run a high pinion in the front.
99blackSE is offline   Reply With Quote
Old 10-16-2010, 09:05 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
The reverse cut used in the high pinion diff runs on the drive side. That's what they're for.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 10-17-2010, 04:16 PM   #4 (permalink)
I stand corrected then. Perhaps I'm thinking of the low pinion...
1991 4Runner SR5 - 22R-E - G58 - daily/mild trails
1984 Pickup SR5 - 22R - ??? - work to do
Goners: '91 V6 4R SR5 x2, '93 V6 4R SR5, '84 4R SR5
