95 3VZFE 3.0 Auto Transmission only shifts manually?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 10-11-2010, 02:03 PM   #1 (permalink)
New to TN
View 1MZFEfan's Photo Gallery
USA 95 3VZFE 3.0 Auto Transmission only shifts manually??
I have a 95 4runner 2wd with the 3.0 V6 and the auto transmission. Transmission will not shift at all on its own but shifts very smooth without problems when shifted manually through the gears. The O/D light also flashes.
I kinda doubt all the shift solenoids would go bad at once...is there a shift control module or sensor that could be causing this? Truck only has 145K and hasn't been abused at all.
Any help would be appreciated. Thanks!
95 Camry LE Coupe Auto V6 321,772 miles Runs like new!
95 4Runner SR5 Auto 3.0 145,000 miles Looks and feels like new!
1MZFEfan is offline   Reply With Quote
Old 10-13-2010, 08:30 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
1MZFEfan,
Will it shift down to low and not up shift or does it stay in high gear making it difficult to move?
jetwhine is offline   Reply With Quote
Old 10-13-2010, 08:58 AM   #3 (permalink)
New to TN
When you first put it in D it starts out in either 2nd or 3rd gear making it impossible to move. You have to put it in 1 and manually shift it through to D. I don't believe it is using Overdrive either. It has shifted down maybe once or twice on it's own but it won't up shift at all on it's own.
Old 12-01-2010, 01:15 PM   #4 (permalink)
SpokaneOutdoors4x4's Avatar
View SpokaneOutdoors4x4's Photo Gallery
make sure your throttle postionns sensor is hooked up. I just did a engine swap and had the same problem and tht was the issue. forgot to plug it i. so if it comes undone or is bad then that will be ur issue. is u check engine light on?
SpokaneOutdoors4x4 is offline   Reply With Quote
Old 01-21-2011, 12:53 PM   #5 (permalink)
View Mantis's Photo Gallery
hi i got same truck the same problem too.. i got code #42 (vss n0.1) .. but everything works on my speedometer.... ive change the vss on tranny still the same thing.. i'm wondering if its just the cable or do i have to change my speedo? help pls.
Mantis is offline   Reply With Quote
Old 01-21-2011, 06:17 PM   #6 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Originally Posted by 1MZFEfan View Post
... The O/D light also flashes.
That's telling you a trouble code has been stored in the ECM, read it and go from there.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 01-21-2011, 06:20 PM   #7 (permalink)
out on bail
fourwd1's Avatar
That VSS is part of the speedo, but it doesn't affect operation of the speedo. I don't think it can be replaced except by replacing the speedo.
89 4Runner - stock
