Reliability of the V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 11-11-2010, 03:25 PM   #1 (permalink)
View TheRockgod's Photo Gallery
I know that Toyota has gold with their bulletproof 22R 4 cylinder and other engines. What about their 6 cylinder engines? What are some issues that you have had in the past or are having in the present and what are common issues with Toyota 6 cylinder engines?
TheRockgod is offline   Reply With Quote
Old 11-11-2010, 05:59 PM   #2 (permalink)
Gameroom cash: $819301
View zythr's Photo Gallery
Sludge and/or Headgaskets for the V-6 especially the 3.0 liter ones. Not such an issue with their near bulletproof Inline 6 which is just about in the same league as the 22r.
zythr is offline   Reply With Quote
Old 11-12-2010, 09:24 AM   #3 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Rock,
The Older 3.0L v6 has had issues with the head gaskets due to heat and expansion of the aluminum head and the cast block. The heat issue is with the crossover pipe at the back of the motor. The best 2 fixes are:
1) New head gaskets and resurfaced head and block to near zero flat .
2) Headers that eliminate the crossover pipe in the back of the motor.
The newer 3.4L v6 is a much more hardier motor. The first couple of years had a few issues with the head gasket but the newer ones are moe better.
jetwhine is offline   Reply With Quote
Old 03-20-2011, 04:22 PM   #4 (permalink)
So, in the long run, for the V6, what years would you recommend as being worth my time?
Old 03-20-2011, 08:02 PM   #5 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
The 3.4 came out in 96, the 1st few years had some problems, I think they worked out the problems around 98-99, IIRC.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
