I just bought a '91 4 Runner. I live in the midwest, so of course it's getting rusty. I'm having trouble finding patch parts to weld in. Can anyone tell where to look? Rear wheel wells, and front cab corners.
Try here and here.
If you search a bit you'll find more.
I ordered my Passenger rear quarter from Alpha steel in the second link.
Here is what it looks like when it arrived.
Here was my rear quarter...
Building the underside and test fitting... Note.. the rear quarter was trimmed to fit for the repair. Please note that all the rust was ground out, sandblasted and sprayed with rust converter and weld through primer. I did not weld new metal onto all that rust. LOL
All welded, smoothed, fiberglassed for rust proofing on the welds, light skims of body filler, pinholes filled in and ready for primer.
3 coats of primer.
Cab corner was cut out. The old one was used as a template on sheet metal purchased at Princess Auto, then welded in place. No pic of the welds on it yet. Sorry. It is installed.
Sorry for all the pics but I wanted you to have an idea as to what you were getting into.
Thanks guys.
Looking good GOT BOOST. I'm not going to go that far, and whatever body work I do is getting covered in truck bed liner. I just don't want to try and fabricate everything. A good portion is just going to be some sheet metal I hammer close and then slap some bondo over to make it close. Snow's coming and I don't have unlimited time or cash.
If you repair it like that it will be a very rough repair and noticable..
Are you going to be welding the metal together?
Make sure you fiberglass the weld marks or the seams to prevent it from rusting further. At the very least use seam sealer. Otherwise all that time and effort will have been wasted.
If you just slap body filler on there, the filler will absorb moisture over time. It will cause it to crack and fall off. As a general rule you only want to have about 1/8 of an inch deep of filler on a vehicle. If you do not sand and feather out the edges, you will notice it when the primer and paint is applied.
Perhaps my wording wasn't off.
I'm going to weld the pieces in. It's all going to to get ground somewhere close to smooth, probably primed. Then filler, maybe fiberglass depending on depth, sanded smooth. More primer, and bed liner to top it off.
It's not going to look 'good'. But, it should look decent.
I'm running out of money, otherwise I'd replace all the rusted pieces with new. But funds are dwindling, and I think damage control is more the direction I'm heading in.
No worries,
I did not know how you were going to do the repair. I have seen some very questionable repairs.
if you are looking at damage control I would recconend:
1) Weld through primer.
2) Fibreglass resin. This will water proof your welds. you can add a small application of body filler on top.
Both items are very inexpensive to purchase and will go a long way in the repair.
**************** dot com, but they say they're backordered up to June 2011!
