22r boom knock knock knock - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 11-24-2010, 11:03 PM   #1 (permalink)
View beaver_scott's Photo Gallery
my cousin has a 4runner with a 22r. he just had the cluch replaced and two days later goes to start it in the morning and it idles rough. he revs it and it makes a boom noise, then a clunking noise and a rough idle. the mechanic says its a bad valve and he needs a new motor (the motor has not been taken apart yet). any opinions? do you think he could get away with just a top end replacement or do you think there could be piston damage?
beaver_scott is offline   Reply With Quote
Old 11-25-2010, 12:08 AM   #2 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
beaver_scott,
That all depends on what other damage has been done. If the valve broke then I would assume that it went into the cylinder and caused more damage. Maybe you can find someone that has a borescope and look into the cylinders and see if there is any other damage. Then at that point you can determine if a engine replacement is needed. It might be just a head replacement. Or, if no damage, just a head overhaul.
jetwhine is offline   Reply With Quote
The Following User Says Thank You to jetwhine For This Useful Post:
beaver_scott (11-25-2010)
Old 11-26-2010, 10:09 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Definitely have it checked out further. Saying you need a new engine right off the bat is really jumping to conclusions.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 12-03-2010, 03:25 PM   #4 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
A compression test will tell you alot.
sam333 is offline   Reply With Quote
Old 12-03-2010, 08:07 PM   #5 (permalink)
sam333,
If that valve is broken off inside of the cylinder the compression check would not be a good idea.
Old 12-03-2010, 11:21 PM   #6 (permalink)
You have to start testing somewhere and givin the description , sounds like he has some major mechanical problems. Turning the engine over with the starter 5-10 times isnt going to do any worse damage than he did running it with dropped valve or valve head). You really have to use common sense in anything, if he thinks its dropped a valve, then he needs to pull a plug and look or pull his valve cover to see whats happend , no bore scope needed. You can always do a leak down test( that only requires you rotate the engine by hand).
