Wont go into 4 low - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 2nd Generation (1990-1995)
2nd Generation (1990-1995) Discussion area for the second generation Toyota 4Runner.
Old 12-10-2010, 12:03 PM   #1 (permalink)
View metaleg's Photo Gallery
2nd Generation Wont go into 4 low
Hello all, I just bought a 90 v6 manual runner with 133k!
I just found that while 4 hi works i cannot move the transfer case lever to 4 low.
any suggestions?
Thanks!
metaleg is offline   Reply With Quote
Old 12-10-2010, 11:11 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593155
View fourwd1's Photo Gallery
Try it while moving slowly forward and backward.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 12-11-2010, 09:39 PM   #3 (permalink)
forward and back
Thanks for the reply, I have tried slow rolling forward and back. Today it went into 4 high and fought me coming out. After a minute of terror at the thought of a 200 mile trip it came back out. This vehicle has been sitting so maybe just use will free it up.
Anything else come to mind?
I have a rear abs light on the dash and the cigarette lighter does not work. Is there an electrical component to the transfer case that limits hi/lo range?
Old 12-13-2010, 04:42 PM   #4 (permalink)
out on bail
fourwd1's Avatar
No, there isn't.
You might try reading the error codes to see if it gives you any info to help with the ABS light.
89 4Runner - stock
Old 12-16-2010, 12:36 PM   #5 (permalink)
View GOT BOOST's Photo Gallery
Has the powersteering system been worked on recently? When working on the powersteering system, you also need to bleed the brakes. I don't know why, but Toyota runs the PS lines to the ABS actuator. Sometimes working on one system will trigger another.
As for the 4WD system, is there fluid in the transfer case and also front diff?
I have 2 electrical connections on the front diff in my 1995 4Runner.
My guess is that there is something in the transfer case that is not allowing you to make the switch into 4L. Check and or replace the transfer case fluid and see what happens.
Parting out 1995 Toyota Avalon XLS.
If you need something send me a pm.
GOT BOOST is offline   Reply With Quote
